Hello, first off, I'm just coming to the end of fitting my van with new equipment:
Anyway, not being too familiar with my new 'Fonda (fake honda) powered compressor, I was wondering what the pipes that go from the pilot valve to the compressor heads do?:
And also if it was possible to fit a pnuematic throttle control valve to the engine?:
And finally, when you manually move the throttle lever, it relies on a Spring to be pushed to open the carb? You can just see the spring in the above picture between the adjustment screw and the rod that goes to a lever beneath the tank. The throttle sort of connects to another lever under the tank, which then connects via a lever to the carb. I no Hondas also do this, why does it push against the Spring (which just bends) ?
Cheers!
Cheers!
