shenion
Tool Pack Rat
- Stone Mountain, GA USA
The capacitor value is only to absorb spikes. Normally there is 0.5uf across each diode to eliminate spikes and also RF interference.
No if you wanted to add enough capacitance to get smooth DC, you would need a lot and 50/60hz would make a difference on size.
I think I calculated it would need about 100,000uF for 100A at 60 Hz to get about 25% ripple. That would be 120,000uf at 50Hz.
A MOV would help more than caps as it will clamp spikes and still allow the reactance to provide smoothing of the arc. If you add a lot of caps the arc will become harsh as the reactor is on the far side of the bridge.
A voltage spike will cause the diodes to avalanche and then the become a dead short until current goes to 0.
I'd look for some 200A or better diodes or diode modules (2-diode bricks.) THey can be had fairly cheap off ebay. Here is a set of 10 that you could parallel the diodes for 300A. Would still need protection.
