shenion
Tool Pack Rat
- Stone Mountain, GA USA
Yes, I get real nice arcs with the Airco on AC with stick. However, I use DC as it has a cleaner weld.
With stick you have the flux "burning" producing an ionized gas. It stays ionized well through the 0 crossings so the arc starts right back up on the next cycle.
With pure argon, the gas ionization stops quickly. So, after the arc stops, the voltage needs to get past the ionization start voltage.
Yes, the big molten tip helps. You also run higher currents. With TIG you can run very low currents (mine goes down to 5 amps.) HF is real important on low current.
I have also seen mention that the Al oxide interferes with the arc.
