I can't find one for air that looks the same as that one from the reel imageThe part you have linked to is way over spec for an air line. More likley to be one for a pressure washer with that pressure rating
I don't think that one would work. I think the part needs to be like the one I posted before, because only one of the parts should rotate and it should be 90 degrees to the main shaft. What do you think Ton-Up??
The part circled consists of the shaft with a straight fitting on the end. The brass piece at 90 degrees spins on the straight fitting and is held on by the circlip on the end. The straight fitting has a hole to line up with a recess in the spinning part. There are seals (probably o-rings) between the two parts.
I think that is the only one that works for the air hose reel, since i can't find any for air that has the same shape/characteristicsUnfortunately in the world of mass produce cheap items they like to use one item for multiple purposes.
According to the table here, 1/4" BSP is 11.4mm inner diameter? I have 10mm hose (and all my fittings must be 1/4" BSP, now I think about it) so looks like this is worth a punt for less than a fiverThe one linked to by @pondy should work. The bolt would allow the rest to swivel around it and the upper part could be rotated 90 degrees to allow the supply hose to enter from the side. Not sure how durable or if would add too much of a restriction. Depends on what you use the airline for
Edit: I'm in no hurry to try this so have sprung for the £2.10 version from China
What is the exact name of that part, so I can find it on ebay?That would work, but it doesn't have to be 90deg as its the inlet. It could be a straight hydraulic type swivel connector like this with appropriate fittings:-
edit: this one would be better:-
r:-
i ordered the exact one a few days ago, im awaiting its arrivalRetractable air hoses are so cheap these days it's not worth messing about, I bought one of the big ones from Aldi many years a go, the hose on it perished pretty quickly as it's mounted in an open barn. Even after replacing the hose with a really flexible 20m one from Pirtek it still only owes me £70. Don't know why you would want to be rewinding it manually when a quick tug allows to retract on it's own.
£43 delivered!
http://www.ebay.co.uk/itm/Brand-New...154160?hash=item36148f1070:g:M1AAAOSwBLlVNNlw
