Onoff
- Sevenoaks, UK
Nothing wrong at all with heat pumps.
However, British housing stock is woefully badly insulated. House builders are notorious for skimping on airtightness detailing and insulation. The care just often isn't taken. Finish the show house and do that properly then apply the test results to rest of the estate.
Also heat pump makers and installers just want to make heat pumps and install them. There's so much money available to be made what with the government pushing them it's pretty rare a surveyor or company will tell you your property is unsuitable.
I bet there's very few people on here realise the level of detail needed.
Where they're fitted and struggle they will just try and run all the time. Ideally a low energy heating system gets the property to temperature and the heat losses through the building fabric are low and slow, otherwise the "boiler" or whatever will just short cycle.
Got to be one of the biggest cons of all time and will potentially use loads more electric than it could irrespective of the 3 or 4:1 or whatever efficiency.
