sport1901966
Hi All,
I am hoping someone may be able to offer some insight on some air tool issues I'm having.
I've got one of the ALDI (powercraft I think?) compressors, but I having trouble getting any effectiveness out of it at all.
I bought it with an impact gun and it always seemed a bit weak, I was always better off just undoing bits by hand.
My uncle then bought me one of the Snap-On MG750 impact guns, it was still quite weak, but at least the gun was ruled out as the cause. I was having trouble whereby the gun wouldnt always run, a lot of the time it would just vent the pressure without spinning, and when it did it was weak. I then looked in more detail at the gun requirements and it recommends a minimum hose diameter of 9mm. I have now bought some 10mm hose and after messing around with the fittings eventually got it hooked up.- I bought a couple of female quick couplers with male threads to go on the hose, only to find they are a different type to all the fittings I have with the compressor (based on screwfix listings the ones with the compressor are 'Universal' whereas the new ones where PCL i think). Unfortunately the tools are for the most part still just venting the pressure out the exhaust instead of running.
From what I have read I thought the Aldi compressor should be sufficient to meet my needs - I dont need to be running it a lot, just need a burst of power to undo suspension strut top mount nuts, run an airsaw etc. I'd have thought with the tank pressurised to 8 bar there should at least be enough flow for a short burst of high torque from the gun, but even then it'll tend to vent the pressure rather than run.
Its very frustrating as the compressor an tools are as good as useless at the moment. Have I got something set up wrong with the compressor? I have checked the oil, ensured the tools are oiled etc, otherwise I am at a loss!
Any advice/suggestions are much appreciated!
