Erie Fred
- Erie, Pa USofA
Hey !They do seem to be out to corner the market sometimes though
I resemble that remark.....
I use them a lot and find they are just as safe, if not more so than the smaller grinders, well if used properly. I couldn't use a petrol saw for the stuff I do, would never get it into the places required.I hate 9" grinders if I have to cut something big its the petrol saw always so much safer, ever since my brother in law had a good attempt at cutting his leg off with one a few years back I avoid if possible. The one time I had too was on my second welding table which is a 2ftX3ft bit of 1" plate I used a dished grinding disc full contact to clean up the surface it was very scary
Contrary to popular belief.....The US does not have a lock on stupidity.....it's a worldwide curse.
1. I'm only qty (1) person of a country containing millionsPerhaps, but your side of the pond does keep setting the bar height, generally.
...and make sure to lock the switch on.....Twisted wire brushes are best things for guardless use. Be sure not to wear any eye protection too !
You don't need eye protection as long as you squint.Twisted wire brushes are best things for guardless use. Be sure not to wear any eye protection too !
when they hit you those wires coming out can really hurt !You don't need eye protection as long as you squint.
The wires could pin your eyelids shut !You don't need eye protection as long as you squint.
