Paul99
Interesting that the offset flue worked, I want to get building again! I also had problems with burning in the feed tube and smoke when the air was fed through an auxiliary feed tube, the burn was better too with a lid on the feed tube. I wondered if the auxiliary air was blocked off just before the feed tube lid was opened the draw might stop the smoke exiting the feed tube, something like a lid that closes the auxiliary air before the feed tube is opened. Maybe the burn area needs insulating to reduce the losses and increase the temperature like the ones made from fire bricks. Great project and videos.
Well it worked blowing ash through the stove with the airline but is not anywhere near as impressive in terms of speed or smoothness of rotation as the flames in the riser. There is no evidence of rotation left at the end of the flue in use (not that I would expect it) I remain to be convinced it makes any difference in actual use but was worth playing with none the less.
I've had another go burning sawdust again this afternoon in-between work and managed to get a burn lasting 3.5hrs. With some better fire rope seals I learnt a bit more this time - the biggest thing being that standard 32mm waste pipe is too small to form the flue through the sawdust with - it doesn't allow enough air through and smoke ends up being pushed backwards out of the feed tube / air supply for a good 20mins before everything gets up to temp and the flue has increased in size a little. The second thing is that as the sawdust "flue" gradually increases in size (as it's meant too) it draws more air and obviously has exposed a greater amount of fuel too - the result is a slow but steady gain in burn rate as time goes on - a positive feedback loop which would definitely reduce burn time if not kept in check by limiting air supply as it occurs - this effect was no doubt made worse due to having too small a flue to start with and having to have air supply wide open to try and get it to draw right. I'm assuming that by increasing the sawdust flue diameter from the start the burn rate can be kept fairly constant by limiting air supply right from the off and additionally draw should be better and smoke drawn through properly too. Didn't get a chance for pics or videos today but will hopefully get some tomorrow afternoon.
