IPA, meths, vodka. Just about anything solvent-y. Even soapy water may do it.anything in the shed i can use to clean it up ? dont have any specific elec cleaner
Am I the only one here that desolders with a short bristle paint brush
Bob
Nope. In a past life of electronics repair I've used all techniques - anything to get the job done. There's a world of difference between desoldering small smd resistors, multipin components and large copper busbar. Then there's heavy component leads on tag board... Ingenuity always required.Am I the only one here that desolders by whacking the board against the bench so that the molten solder flies off
(Actually I have a solder sucker now - never really got on with braid...)
I do a lot of repairs to Quad wiring, and find solder doesn't stick too well to the wires, often they have turned black under the insulation due to corrosion. I guess stuff like Bakers "killed spirits" would work, but that is not recommended for electrical applications. Usually can't take a bit more wire off as it disappears into plastic conduit, or is close to a wiring plug. How does everyone clean blackened copper wire to get it to solder.
I get that a lot on what I doI do a lot of repairs to Quad wiring, and find solder doesn't stick too well to the wires, often they have turned black under the insulation due to corrosion. I guess stuff like Bakers "killed spirits" would work, but that is not recommended for electrical applications. Usually can't take a bit more wire off as it disappears into plastic conduit, or is close to a wiring plug. How does everyone clean blackened copper wire to get it to solder.
Fine wet and dry paper.
I find either wet and dry or wire wool
This may sound stupid but can you use any sort of electrolysis?Right, so mechanical abrasion, more or less how I do it now, I've been scraping the corrosion off with a knife, but it is difficult to get right round each tiny strand and, if you don't, the corrosion seems to creep over what you have cleaned when heated, particularly once the flux hits it.
Compressed air blow gun makes a wonderful desolder-er.![]()
