Bought a second hand 5" angle grinder from an auction for £2, label on it saying that it had failed the test and do not use. I reconned I had done ok because all I wanted off it was the nut that holds the disk on, (one of them once cost me £5 from a supplier).
Just for fun though and curiosity I took the grinder apart. Found the brushes were completely worn down and the commutator blackened and slightly grooved. Took the armature out and put it on the lathe, skimmed commutator with parting tool and finished with wet and dry 300 grit.
Now, I have like copper burrs between the segments of the commutator. Do I need to scrape these out or will it be ok to try with new brushes as it is?
