Rig Pig
- Narrwich! U.K.
Do they really, are are they running, and cycling as described in the previous post?
If they're running at 'full capacity' as you claim, then someone sized them wrong. Fact.
Good luck with your Quincy, Junair and IR recips running flat out 24/7/365. The world has moved on for these sort of applications and now use rotary screws.
As stated above in normal operation, a compressor setup rotary or reciprocal usually has a tank, and offloads or shuts down during periods of low demand, however obviously a 100% duty set is capable of running full chat when required.
The rated capacity of a piece of process machinery is the full load sustained output. Fact!
