I cut a piece of supple leather from a welding apron, and have fixed it on the back of the helmet with velcro so that it drapes down my neck blocking rear entering light. Makes a HUGE difference as I wear varifocals and have a cheater lens, so there are lots of places for multiple refractions and double imaging.
I'm about to go on holiday, so I just tried a quick experiment (before I read awemawson's response) by attaching a piece of fabric with duct tape to my helmet so that I looked like an old-fashioned photographer. I can confirm that it does make a huge difference. I too wear varifocals and have a cheater lens. I'm also bald as Friar Tuck, so I wasn't sure if a head scarf would have worked in my case.
Havent done much welding recently but finally tried your tips out last night with putting something over the helmet to block out the light. unfortunatly i still cant see very well, its better then it was before but its still not great.
The helmet is on its highest shade setting, but i am still getting blinded by the arc and still cant see much of what im doing.
I might try a cheater lense in it see if it make any difference.
I took the helmet apart tonight, after not being able to see again, and found another protective film. (I thought i removed them all on christmas day).
The difference was unbelievable. From basically total darkness with just the arc, to being able to see everything.
However im not sure if i was supposed to remove it? It didnt have the little tag, that you use to peel them off, like the ones i removed at christmas did.
I know this might sound abit daft, but i just dont want to go blind.
IIRC, glass absorbs UV light, as does polycarbonate, so you won't get arc eye. However you may suffer retina damage from the sheer intensity of the arc.
It just seemed too clear, compared to the fixed shade i was using before.
My eyes did feel a bit wierd after using it but it wasnt "arc eye".
If i remeber correctly, the film i removed was on the inside of the lcd part.
I'll try to take a video through the mask, to show how clear it is.
