LewisT
- Central Scotland
Not got a lot to show since the previous post but have done some small things, bought jotun 90 last year accidentally bought the non wintergrade version so put off using it till now, anyone think this can is under filled?
Anyway on to the rest, never used two pack paint before in fact not ever done much painting before and the brush finish on the first use wasn't great. tackled these areas first as i need to the this back together to move forward
Stuff was mixed 3.5:1 i dont think i use enough thinners was really thick and didn't flat out very much.
The part is nearly ready to be welded back in, made a bit of a mistake in welding up the cuts on the ribs where i folded it, should have done this after spot welding to the chassis leg the angles on the flanges don't quite match the chassis leg so might cut them open again before welding it in.
You might also notice i have cut out the inner wing out again it looked crappy and wasn't happy with it, its only a flat piece with a few ribs down it not much of a problem to redo.
