That's good information; I can't thank you enough. I'm thinking about getting a special pair of eyeglasses that allows me to read print at an arm's distance on the 2/3 lower half, and then have clear non-prescription on the upper 1/3 half. I only need distance glasses when driving. I'm wearing my reading glasses right now and the screen is an arm's distance away while I'm typing; that works out just fine for welding too. But when I'm at the end of a weld pass and need to flip my hood up, everything past an arm's length will be blurry. So if I need to get up and walk around after making a weld pass, I can't do that without removing my eyeglasses. And I have to take the hood off first because the headband clamps around the eyeglass temples. If you read all that, I appreciate it.ex opticians tech ,,, get a pair of glasses for welding , if you need glasses for reading then you will need a separate pair for tig , you tend to tig weld closer than you read , mig you may get away with .
get decent frames with flexible hinges , and either the cheapest pair you can find , or a brand you can get sides for as spares , if you wear glasses daily then go for bi focals but aim for a d32 instead of a standard d28 , bigger area magnified , and set the height about two thirds up the frame , a larger metal square frame will tend to work better ,,,
trick is to speak to the optom and spend time getting what you actually need , not just what they want to sell you ,,, make sure you get a copy of your script and include your pd . then just order a spare pair off the interweb for humble money ,,,, and two important things ,,,
1 ,,, look after them , no face down on the bench ,,, you soon get the habit
2 ,,, wear them , they are no good in the box in the house , you have to wear them to get the good out of them.
thats in brief ,,, any questions feel free to pm, if I can help.
