BrokenBiker
- Newport, South Wales
i only ever actually use it for marking out ali or brass...i prefer torch bluing steel and scribing for marking out dimensions on small parts
Also good for coating a surface and then scribing to get a real good clear ultra fine line.engineers-blue - is paste in a tin or tube used for mating surfaces-accurately together then scraping till perfect
Sharpies are in the pound shops now. Much more affordable.Sharpie markers for the more affluent among us I use anything that is handy sometimes just to scratch a line if I am cutting out roughly to shape.
marking blue (liquid painted on) for marking out.
they must have to be kept dry then do theyA box of these, never found a blunt one wet...
http://www.screwfix.com/p/goldscrew-woodscrews-double-self-countersunk-5-x-80mm-pk100/17131
Yes but if you only have engineers blue then it can do both jobsEngineers blue (paste) for checking mating surfaces, marking blue (liquid painted on) for marking out. Two different products.
Yeah, we only ever had the paste version, used normally for doing high spots, mating surfaces etc or as you described to blue a surface for scribing. Sometimes thinned it down with meths or similar solvent but more often than not just wiped across neat with a rag as you say.i hate the liquid version, had to use it in college and we actually got marked down for using the paste instead, the liquid was always kept in a manky bottle and everytime you used it you either needed gloves or got covered in it... with the paste i just dab a bit of paper towel in the tin, smear it over the material and then wipe the excess off, throw the towel away and its ready for marking out with no time needed to dry off
BB
Get realistic.
You need a million bits of chalk and you will still never be able to find them.
There is a full box of engineers chalk spread around my single garage, yet can I find it???this will no doubt be the case in the end...when i started welding again for my own needs i bought a bulk pack of 30 fake sharpie markers in black and red and within a week i had lost every single one of them and had resorted to a ground down drill
