Arsonista
- Mid Wales
Carter, I spent most of my apprenticeship making square to rounds. What you need are what we called 'fingers' and a flipper, (old leaf spring). A piece of 4x2 will do at a pinch. The fingers you can make from 2 pieces of angle, say about 30 x 30 x 6, and cut a shallow angle of 30 degs on both legs at one end. The length of the angles needs to be the length of your vice jaws plus the length of the workpiece plus about 50mm. This is getting difficult to describe. Put the angles back to back in the vice with the 'pointed' ends on the left of the vice enough to cover the length of the workpiece. Now drill 2 holes through both legs either side of the jaws and pin them. That's the fingers made. Your pattern development will have 4 'points that are the corners of the square end. You need the triangulation lines now. These are 4 lines that will come from each corner to each quater of the round end. Now pinch the one of the corners in the fingers next to the vice and flipper it over while raising the round end to the the last triangulation line. Do that 4 times and voila. If by some miracle any of this makes sense, draw something up for us to look at. When I was doing this, the technology was marking out blue, dividers and a scriber.
