Hi Folks,
Our tRusty old T4 failed its MOT on rust, rust and more rust.
I recently did a night class to learn metalwork, we did MIG, TIG, Plasma cutting, Oxy etc. The van failed the MOT 3/4 through the course, so I quickly wrapped up my "project" (a 3-legged plant stand) and focussed the last 2 weeks on stitch welding 1mm sheet metal with the MIG. While it wasn't pretty, I was managing to get full penetration and overlap on the spots and when ground flush there were only "many" pits and voids, rather than it being totally detatched haha!
I spent a bit of time looking for, checking out and narrowly missing out on second hand Clarke 135s etc. and decided life was too short and ordered a new Blackline 200, thinking that they 1) get good reviews on here and 2) should be a nice simple baseline to start from, so any "issues" would be down to technique and not because it's a crusty old second hand welder and 3) 1 year warranty.
So, I messed around with some 2-3mm steel, doing some runs, welding old bolts to it etc. Seemed easy enough to get settings to work, wire fed smooth and welds look ok.
I then cut some pieces of my 1mm sheet (plain mild steel) that I bought for the van repair and this was where trouble started.
I had accidentally bought Hobbyweld 15 instead of 5, so went back and got that swapped. Hoping that was my issue sorted, I cracked on with some more practice.
Issues:
Even when I have the voltage down very low (less than 1/10) I keep getting insanely hot flare ups. So bad that it seems to flash-vapourise the top sheet of 1mm steel (was practicing overlapping welds). The mig wire turns into flying little blobs of molten steel and plugs the tip. I've tried upping the feed to the point of getting pushed back from the weld by the wire and then backing off a bit. Sometimes this helps, but then every once in a while it just goes nuts again.
When things are going ok, it settles down and creates a weld pool and I can control the arc. It seems like I'm on a bit low a setting as I'm getting very protruded beads and not a lot of penetration, but if I up the voltage even a tiny bit I go back into flare time!
What to do?
I'm not really sure what's going on. I've done a lot of googling about burn-back etc. and it seems like my wire feed rate it ok, tension ok (if I grip the wire the feed slips but only with decent pinch force), and i don't notice any obvious stuttering of slowing down of the feed (I had wondered if my weedy garage power supply was dropping voltage when the arc was kicking in - the supply wire is too thin and I should really get it upped to 4m2 - bloody cowboys that installed it before we moved in.
I've tried new tips and it still sometimes happens first pull of the trigger.
Setup: 0.8mm wire, 0.8mm tips, 12-14L/m gas, hobbyweld 5%. Voltage about 1/10 and speed 2.8-3 / 10.
What I've tried:
I thought it could be a bad ground, so I checked the earth point in the welder and torqued it (it was fine). I cleaned up another bit of the frame of the van and made sure I had a really good earth.
I've run some beads on some thick bar with the settings higher and managed ok looking welds. Even attached an old screw to it and couldn't hammer it off for love nor money, so the welder CAN work fine, it's just frustratingly inconsistent.
Here are some examples:
1st weld, ok:
First attempts on thin steel, short runs, spots and some seam stitch - a total mess, blasting huge holes (Hobbyweld 15) etc:
Close up of one of the bad flare-ups (note, settings were 1/10 Volts, around 2.5-3/10 speed (hobbyweld 15):
Issues:
What to do?
What I've tried:
1st weld, ok:
