a cheapo pot of ebay and fit a 3mm carbide nozzle on the end of blast hose or make your own potWould like to get a blasting pot for mainly car panels and parts etc. I have linked to 14.5cfm compressors together, what would be a good, reasonably priced set-up?
it will run nicely @ 90psi with 28cfm
They're good value for money, I used mine with a couple of 3hp compressors and they will operate larger than 3mm OK. It depends what you're blasting, I did scooter frames and other fairly intricate parts so you don't need a lot of air or you have difficulty holding the workpiece steady while you blast it.
I used the larger nozzles with coarse grit and switched to smaller nozzles as the grit wore down. No need to buy larger nozzles, even the carbide ones wear eventually so a 3mm becomes a 3.5mm and then a 4mm.
Best to go for a 20gallon V a 10gallon? Not much difference in price, assume the larger can just go longer with more grit but apparently from that no performance difference?
never get it finished lo.I've got a 20 gallon that I don't use and has only been used a few times but the shipping would be tricky.
How much and where are you postcode wise.
there totally useless with even damp sand .if it did work must have been a large pot with a big blast jet and sand like slurry or it didn't happen...which also makes me want to ask -
What are the pressure pots like with wet sand?
I got a part blasted once, as a cash job - chap had a road compressor, and just emptied a bag of cheap wet sharp sand into the pot (total loss setup) and it worked. I don't know if this was due to the massive volume of air, or somthing with his pot... Or neither?
