Grrrmachine
Just one more bit :x
While fitting a new fuel tank, I noticed a little bit of orange around the hard fuel lines. It was at the bottom of the new sill that I'd paid someone else to fit two years ago; that's one year on the road, one year in this garage. So I put the wire brush on the angle grinder to see how bad it was...
NOT a happy bunny! The garage I had paid to fit a brand new outer sill had done just that; slapped the new outer over the existing rust, and slathered the rear of it with seam sealer to mask the crusty bits.
There was no other option but to get the slit discs out, and remove the outer sill to see how bad the damage was:
A lot of curse words were used at this point. The idiots hadn't bothered to remove any of the rusty inner sill when they'd had the chance to do so, and now it had festered to a dangerous point. At the front end, there's hardly any material left for the floorpan to affix to, and under the B-pillar is a horizontal support beam that is now attached to f-all.
Cutting and grinding got me back to clean metal. Fortunately I was below the spot-welds at the rear end, but the front section is essential to put some rigidity back into the floor. So some fresh 1mm sheet was used this time (no sunroof) to make a repair length - 1.16m long.
An afternoon with the MIG got it all seam-welded to the existing inner sill, then plug welds where the original spot-welds were.
Then it's time to offer the outer sill back up. This is how I chopped out around the B-pillar, so that I wasn't too close to the original seams.
And the outer sill going back on. Now it's just a case of welding the sides up flush, and putting the plug welds back in place top and bottom. And that had better be it!
