So if brazing isn't welding... it must be soldering...![]()
What size of tip and psi of air do you recommend to start with?
dont bother it will just blow out the second you try and light it . its difficult enough using propane and pure oxygen but well; doable
You did. I'm damned if I can find an image on line, though. Fed from a small compressor and town gas.If I recall, the torch I used in school had a brass body with two 'toggles'(?) one to control gas and one; air
