Screwdriver
I want to run a decent water supply to the bottom of the garden. Been using a bit of hose for years but recently picked up some 15mm polypipe. Its the regular grey stuff.
The first step is to go across a side path which I can easily do, just pick up some concrete which has already broken up, lay the pipe then concrete over it. Can I do that with polypipe or do I need a bit of specific stuff? I there an issue with burying the two 90 degree connectors and concreting over them?
I could also do it in copper but the main run (all 35metres) is going to be in the grey plastic pipe so I'd rather keep it all the same.
S.
S.
