Robert1998
- Spain
I can’t remember where I bought the pad, but it was probibly amazon or ebay.
It was an offcut of the pad I bought to go under my leather stamping granite slab, and it was the densest anti vibration rubber pad I could find. There was certainly some weight to it.
Thanks for your answer.
This is my set up
The antivibration pad must go under the 4 legs on the floor right?
I also screw the table to the wall
It makes a lot of noise because the metal sheet of the wall amplifies the sound of the vibration, but i think it gives a lot of rigiditu to the table
I dont think you can get 1" face mills with 4 or more insert cutters, and the 6 toothed cutters I use are HSS so if they go blunt you'll need to be able to sharpen them. you can get get them like this
Dormer Shell End Mills 1-1/4” x 1/2” HSS Metal Cutters (TD21,D3) | eBay
<p>Dormer Shell End Mills 1-1/4” x 1/2” HSS Metal Cutters (TD21,D3)</p>www.ebay.co.uk
but you'll need an adaptor to hold them
a flycutter is an easier option, as it is a single point cutting tool it is easy enough to sharpen (if you have the correct abrasive) or if you use a cutter with an insert you can replace that. flycutters are cheaply available to try (not sure what taper you use though)
depth of cut is relative to the sharpness of the cutter, and cutters need to be sharp, and they need to cut, if the cutters are blunt and the depth of cut is too low, the cutter will rub against the surface which can make the situation worse. What you'll find is that you need to try different things until you find something that works for you and then you'll use that setup next time. Its a learning experience and just use reference tables as a guide. over time you'll get a feel for the machine and what works for you. with flycutting I'll normally use 1600rpm (as I use carbide) and between 0.15 and 0.40mm depth of cut (depending on material and finish) I have no idea of the feed rate but it'll be somewhere between 0.5 and 1.0mm per second. if you look at the larger flycutter tip I posted earlier today the 45 degree angle at the cutting edge reduces the stress on the cuttting edge and gives a better finish than having a vertical cutting edge.
Thank you for the time you spend lloking up for this things!
