Bugger ,,, how many cows will I be needing then ,, air or battery cows ??You only just realised? Some on here can tempt you 'til the cows come home.
and it wont last long without recharging. even less with a constant load i have a fair few mains tools air tools and battery all have there limited uses12V gear isn't heavy or bulky.
do they do a 90 or a 135 degree die grinder on 12v ,, ?The M12 stufff is quite powerful. That die grinder has 4 speeds and a variable trigger so is really controllable. It’s really no difference to the air one, bar the annoying shrieking!
I use all my gear out and about which is why 95% of it is battery. I have a roloc fitting for the die grinder but it’ll take abrasive pads as well as the polishing type. It’s used a lot with a burr and it eats metal
ive run air stuff off the drain on my truck tanks , I replaced the tank drain with a pcl socket , and it was very very handy some days .. and you could still blow the tanks just by plugging in an air blow jun too.I’ve not done it with Milwaukee as I’ve never ran out of power (plenty of batteries and charger in the truck / workshop) but years ago when 12v gear was in its infancy, the best you could buy and still crap, I put an Anderson connector on an empty dewalt battery case to run it off the truck. Did the same with a strap on impact also.
90. I have one. I use it a lot. Mine was a us one which is a pain in the **** as it’s a 1/4” Chuck. They released them here last year, I think it was, and the UK release comes with a 6 and 8mm Chuck.do they do a 90 or a 135 degree die grinder on 12v ,, ?
Further to the above, I suppose what I was meaning in OPs case was why not buy a m12 one (or do you have one? I can’t work it out, sorry!) and see how you go with big ah Chinese batteries. If it’s a no go then why not do what i did on the dewalt stuff but with a 240/12v PSU?I’ve not done it with Milwaukee as I’ve never ran out of power (plenty of batteries and charger in the truck / workshop) but years ago when 12v gear was in its infancy, the best you could buy and still crap, I put an Anderson connector on an empty dewalt battery case to run it off the truck. Did the same with a strap on impact also.
handy to know ,, many thanks90. I have one. I use it a lot. Mine was a us one which is a pain in the **** as it’s a 1/4” Chuck. They released them here last year, I think it was, and the UK release comes with a 6 and 8mm Chuck.
Most air tools are metal bodied, heavier and better quality but very inefficient and noisey.air is more versatile and lighter tools
Would be so much better if er11 became standard but they wont. You could use an adaptor but extra stick out is a pain.Mine was a us one which is a pain in the **** as it’s a 1/4” Chuck.
I have lots of air tools for work however at home my 50ltr compressor would not keep up or will make a horrendous amount of noise in use.12v means I can work without annoying the neighbors.I find the small size on the air tools make it worth the bother , same as running roloc on a grinder , the size of the head becomes an issue , if theres enough space to run a full size 115 grinder run one with a rubber disc and pads to suit . a straight die grinder gets into the very very tight corners better than most things any way.
Wear ear defendersHi all,
Thanks for all the replies. Amazing to get so many replies in such a short time. I've been reading this forum for a couple of years and learnt so much (epoxy primers, rust protection. welding etc) and its simply the best out there. Fantastic forum where people are so willing to contribute.
I should have said that I have a cheap (Lidl) 50L compressor paired with a Lidl die grinder. The comprerssor (constantly on) and grinder combination is very noisy!
I like the idea of the Milwaukee Die Grinder and buying some cheaper Chinese 4 or 6Ah batteries and that might be the way I go.
Phil
Exactly what he said. And brush your face and hair before you take the goggles off. They’re like needlesWear ear defenders
And if your using the die grinder with a burr, you really need goggles not glasses
