Apart from the fact that most inverters have an OCV of over 50V
See here:
http://www.decaweld.com/default.asp?cmd=getProd&cmdID=19306
and cellulosic capable inverters generally have an OCV of 80V plus.
You can't use cellulosics, or for that matter lo hys, on a buzz box with an OCV of 50V.
With an inverter with intelligent control the OCV could be 10V just to detect that a rod is being struck, then it can throw everything at it for 10mS to establish the arc, then go to the set current and look at the voltage across the arc, then decide on the rod being used and select a characteristic suitable for the rod.
Anyway, in the old days when arc welding machines had OCVs of up to 110V on the high voltage range, it was hardly a case of people dropping like flies when they used them.
My own inverters have a claimed OCV of 90V, measured to be 81V, but I've never felt so much as a tingle from them.
See here:
