Screwdriver
Very nice Paul, despite the bickering
Haha. You guys need to adjust your humour sensor. Everything Paul does is usually so bloody perfect! I couldn't resist a little dig.
Your probably right too, and I've often thought about making good quality garden furniture in stainless steel as a product to sell rather than scratting about in food and chemical factories, Finding the market is the tricky part, and probably needs a proper marketing and sales setup.
have you powder opted a lot of stainless? I figure it might last a lot better than on ms?
.....the upholstery department is planning to make a couple of memory foam cushions for them.
These are made from aluminium, but yes I have used powder coat on stainless it works very well if properly prepared.
@Paul. Do you mind if I ask you the angle from the leg and the "sitting part"
and the angle from the "sitting part" and the back?
Maybe next summer I will make a pair too.
Thanks.
SARTo
They are keen tolerances Paul given it was put up from off cuts.Its 100 deg between the seat and the back,
Edit: here is the sketch I made it to
Take no notice of the tolerances, its just sketched in autocad then measured afterwards, all I had to do was use the longest offcuts for the legs, and set the seat at 450, everything else is completely arbitraryThey are keen tolerances Paul given it was put up from off cuts.
