1, The "190" is the "Cold Cranking Amps" ( CCA ), a number mostly used in USA to rate how good the battery could be at starting a car/bike on a very cold day.
2, At that rate, a completely flat 19AH battery would take 10 hours to recharge.
3, cuts off charging when the batteries reach 13.7v,
Mostly good advice but those 3 points need comment.
1, For deep cycle use you really want a battery that does not even have a CCA rating. They are just not suitable & will die quickly if used as a deep cycle bat.
2, Its not as simple as dividing the capacity by the peak charge rate. Not only do you have to allow for the temperature you also need to allow for charging efficiency. Fully charging a lead acid battery can take a very long time (think 24 hours to do the job properly any thing less is a compromise). The charge rate will drop quickly once you get to about 80-90% SOC (State Of Charge) so over the 10 hours you will not have replaced the 19ah never mind the extra you needed to.
3, A voltage cut off of 13.7 will NEVER get the battery to full 100% SOC. You need to get to around 14.4-14.8v & hold it for a few hours (its called an equalise charge) dep on which type of lead acid the battery is to over come the resistance to charge & finish the chemical reaction.
I am guessing that its a bad translation as 13.7v is the float voltage once it is full & not the cut off voltage.
