God mode restorations
- uk colchester
Just out of interest. Are the biggest clarke temporary garages have the same tubing size as the smaller ones.
The garages have the same tubing size. The smaller M/C ones and 'sheds' are a little smaller. I couldn't get through to spares today. I'll try tomorrowJust out of interest. Are the biggest clarke temporary garages have the same tubing size as the smaller ones.
Polytunnel suppliers sell insulating tape to stick on the hoops & bars Its about 6mm thick. It works, my boat shed was put up over 20 years ago with this tape on the hoops & the original cover is still serviceable. I bought a replacement cover recently & the supplier reckoned it has lasted twice its usual lifespan.If you put some of that foam pipe insulation over the bars first you will find cover lasts years longer , due to heat in metal frame in summer effect plastic , found it works and lasts lot longer on my polytunnel . although if its a tailored cover might be a tight fit , its only the roof bars you need to worry about , all the best .
I got tape with my original sheet , it was only about 3mm thick and half inch wide , hence why I changed to the foam padding which worked much better , presuming diffet sellers supply differant quality eh.Polytunnel suppliers sell insulating tape to stick on the hoops & bars Its about 6mm thick. It works, my boat shed was put up over 20 years ago with this tape on the hoops & the original cover is still serviceable. I bought a replacement cover recently & the supplier reckoned it has lasted twice its usual lifespan.
