youll get those a lot cheaper on ebayEmailed clarke today to find out the specs of the capacitors in case I need to buy them. Thought you guys may find it useful..
TZ10023
45uf
450V
£9.45
TZ10026
150uf
300V
£13.99
A compressor with a soft start? !! that is the last thing you need,-------- thick old oil, thick old oil. thick old oil------oil day long ...It starts up (it has a soft start) and after few seconds as it gets faster then it trips out the switch.
no the pressure switch does that the NRV, just stops the tank emptying through it.Is the non return valve the same part that bleeds off a bit of pressure when the compressor reaches pressure or is turned off?
in the cold weather I use 15---20 ish you can use engine oil in straight 20, morris oils do some, none detergent. TBH seems to work ok in the summer, too in uk. dont forget those grades on the machine are to cover spain /greece etc etc. ambient could be 40 ? at that temp 30 would be like 15------ before you hit the button!.Any idea of how much they hold and can i reduce the viscosity as it recommends 30w?
not wish to argue but the stiction IS measurable!--- it is what is left in the bearings on the bores etc etc even the grease in the motor bearing plays apart. as well as water caught in the oil that freezes.I really cant see it being oil...the oil is not pumped but flicked by a thin finger hanging down from the bottom of the conrod,the drag off this must be hardly meaurable![]()
Yes, belt slipping would probably not matter.
