gasket999
getting there...
- Manchester, UK
Well I bought (another) compressor. Now have a pair that will displace 22CFM between them.
Its stamped 2014 - so not very old, but its been through the wars (and was cheap). I tested it before buying by running it up to pressure - took about 5 mins and sounded pretty good.
However, there's two issues.
1) I drained the oil before loading it into the car and it was black - like engine oil black. Not sure that this is normal.
2) (the bigger issue) it is covered in red garage floor paint - the lad I bought it from was spot on and dead honest and said that a tin had fallen off a shelf and landed on it. He'd cleaned a lot of it off, but its everywhere and quite chalky - I strongly suspect that its fallen on it while the pump was running.
I'll spend a couple of days on it and will be stripping it in order to give it a full service and inspection. But, what to inspect and which parts to order in advance?
I'd like to do the job thoroughly - so think the head should come off as a minimum, so a new gasket will be needed. The air filter cover and element was removed (and lost) while he was cleaning the paint back off - so a new filter housing and element will be needed. And in light of this I have to assume its been run a fair few times with no air filter (including the test run) - so I'll need to see inside the pump to check for contamination and may well need to fully strip it in order to clean it out properly.
Is there a rebuild kit for these things? If not is there a list of parts that anyone could advise me to change to be on the safe side? Valve plates? Piston rings? What about muck in the pipework/cylinder?
I'll have to get onto clarke parts direct so may as well make a list.
The manuals online for these are massively generic and don't have a parts list, just a basic maintenance schedule on page 17:
http://www.clarkeservice.co.uk/manuals/compressors/se_ve.pdf
It suggests that inlet and outlet valves, big end and main bearings and piston rings should be periodically inspected and replaced as necessary tho.
I've built car engines but never a pump like this.
Any tips would be very welcome. Thank you.
