An hole near the caster ,I have not intention to repair the hole because I'm sure that will fail againHow did it fail? Rust holes scabbing open, splitting, exploding?
There was some rust in that spot and it fail there
Nothing of dramatic the pressure went down and I saw the water coming out ,nothi no did explode
so none of the usual rubbish about exploding tanks that's bantered about the internet of doom and gloom
But you can pressurise a vessel using it as an hydraulic fluid as happens with oil on the escavators and other big machine with hydraulic cylindersWater doesn’t compress
Yep i miss understood sorry for that ,my badGot cut short on the previous post as it’s not possible to compress water there is no rapid expansion in the event of a leak or rupture more of a controlled event.
Anyway it's past now , it's all okIt’s not your fault it’s where I am at moment, somethings seem to happen suddenly here, I put my phone down and must accidentally post a reply
Yep that's the reason because I wanted to do the hydro-test also if I did at home it worked pretty wellthis test it with water in it
this one is without water in it actual real cctv video footage of an air tank explosion
and another
this is why we say dont use water tanks or air tanks thats been full of water for a long time
