I ran the generator on a low rpm and the voltage was below 200 volts. If I let the air out quite a bit then the compressor wouls start fine on 200 volts.
just a heads up here but under revving a genorator is one of the best ways to kill them.
lower voltage but lower frequency is the key as your dealing with induction motors they are funny beasts. off the top of my head if you half the voltage and half the frequency the motor will still make the same torque ( in theory ) what really messes it up is a large proportion of genorators are the brush type with AVR, that dose everything it can to maintain output voltage ( not much it can do about frequency ) buy putting more power through the rotor. all sorts of funny stuff can start happing but the rotor usally ends up getting over loaded by the avr and at lower rpm the cooling fan isn't so effective thankfully most of the time its the avr that goes pop first and thats the cheepest bit ( usally )
Incidentally, It's not me who's compressor won't start, all my 3 gennys and 4 compressors work fine and I could repair any of them if needed.The one that I run on low revs has to run all day with a very light load, chargers etc, except when the compressor is needed. Been an electronic engineer for 45 years so nowt scares me. I'm more interested in getting his compressor sorted before he spends money on parts he may not need. I usually find it's the pastile dirty/perished or the spring has gone weak.
