the snooper
getting older by the day
- Hull UK
bet it cost more then that
how much did it cost >? u can get a new 3hp motor for 90 quid
im with brightspark, when my hydrovain compressor's motor went bang, i went to a couple of re-winders for quotes, the ******* they didnt tell me the motor was a bog standard type as im sure your one is, had a look on expensivebay got one for under 100
Ya cost more than that alright but not too much more. Had no choice really as they're the only place around that does them.
Have you got a link to the motors????
Any of you guys have an idea about the wiring????
If the motor has a data plate showing the operating speed, check the off load speed now to see if it's the same. If not they've cocked up the rewind.
just ring them back tell them its not right its obviously their fault
unless you have a fault with the pump causing it to run slow
what caused the original winding to burn out ?
How do I check the off load speed?
I can't see anything wrong with the pump as it'll turn over by hand freely.
It was suggested that it could have been the non-return valve but to be honest I don't really know.
You need a handheld test tachometer.
You'll have to excuse me, I have a habit of assuming others have the same test equipment as myself
just disconnect the delivery pipe from the pump and try it, although i would imagine it to get slower and slower as pressure built up if it was some sort of restriction
could be to do with the rewire and the centrifugal switch if that is what type of motor it is
give em it back and tell em to re test it with the capacitors/ and also ask which conections are for the feed i wouldnt even bother trying to do anything with it . u have paid for it so expect good service
