Weldinator
Astalavista baby....
Ive been told via a heating engineer that for air pipes, galvanised steel pipes should be used for air supplies rather than copper. With this in mind, im thinking steel would be far cheaper/stronger than copper and they can be died for fitment.
For my small garage set up im planning on fitting some pipes in a step system from low to high to reduce water build up etc. What have others here done to build their own set ups and what did you use to connect the pipes together, did you flare or die the pipes ?
My compressor will be a max of 150psi 10 bar when i buy that one that is, my current one is 14cfm, 3hp direct drive 50 ltr. It will be used with air tools and painting, short spells of painting/tools though.
What would be the recommended thickness of the copper and steel pipes for the above compressors ?
I'm also im going for 1/2 inch sizes all round, so what would be the recommended tube size for my set up, i thought 15mm would be the ideal size.
