J justin Member Messages 222 Aug 6, 2015 #21 I would like to try a little spraying at some point if this works out ok.
TurtleDude Member Messages 422 Location Worcestershire UK Aug 6, 2015 #22 justin said: I would like to try a little spraying at some point if this works out ok. Click to expand... If you're talking paint spraying, as in automotive repairs, re-sprays etc, you might struggle with a 30 year old 2.2kW piston compressor. Find out what the required Free Air Delivery is for the gun you intend to paint with. And at what pressure. Normally paint guns need very low pressure (relatively) but a decent volume or flow. If you're not using a dryer, filtration etc you might find your paint finishes to be a little sub-par!
J justin Member Messages 222 Aug 6, 2015 #23 I was thinking of painting bike frames, nothing as big as a car but i know that my father in law has used this compressor to spray car repairs and at least one whole car.
J justin Member Messages 222 Aug 6, 2015 #24 new switch fitted stopping and starting as it should. still losing about 10 psi an hour so I will have to try to track down the leak now
rtbcomp Moderator Messages 18,574 Location Sheffield UK Aug 6, 2015 #25 That's good news. A bit of soapy water brushed over the various fittings should show up any leaks. If not there may be a leak through the non-return valve.
