Well i have been given a Clarke compressor model no. SE7AR.
The motor all seems to power up correctly and the pump spins freely, but as soon as theres any pressure in the tank the part circled in this picture just lets the air out. If i put the top of the part circled it will stop the air being released and the tank will continue to pump up, however it is extremely slow to get pressure (it took about 25minutes to get up to 6bar, then wouldnt pressurize any further...
Now obviously the valve that i ha to push the top of will need to be sorted, can this be repaired of will a new valve need to be brought? if a new please could someone tell me what its called?
But i think there must also be a more serious problem for it to take so long to pressurize and not pressure further further past 6bar.
Just as a side not the pressure cut of switch is not stopping it from going further than 6bar, it will continue pumping but not pressurize further...
Any help would be great.
i did try and search for parts, but i cant seem to find anything under my model or serial numbers...
