Hi is it possible to use this compressor in conjuction with my clarke 90 mig welder instead of using co2 bottles only the compressor as a work bench area on top so i could put my mig welder on it and use the air from the compressor.....I need a regulator to reduce the air flow where can i get one from.....thanks....
Hi on the compressor there's 2 oil/water traps...I know that the water trap catches any water in the tank/pipes....but this compressor as a oil trap which lubricates on one of the outlets which i've been told to use this outlet for my air tools and the other outlet is double filtered air to be used with spray gun and other tools that dont need the lubrication...My question is where do i put the oil for the lubriction outlet...it as a small glass/plastic trap with a bit of oil in it which on following the pipe work leads to the lubricated outlet.....Do i just put some oil in the glass/plastic trap....thanks...
