W.olly
- Radcliffe, Manchester
Well after hours yesterday faffing to set this up and get the pressures set, i think. I dont think the two compressors are upto the job.
So as i `think` the settings are ok and the set up ok i hope you guys can confirm eithe right or wrong please.
The set up is
Both tanks Max psi 150psi.
Comp 1 Airmaster 15/60 3hp 50l 14CFM (?)
Comp 2 Jetair J11 50l 3hp 11CFM
Comp 1 Cut in 95psi/ Out 125psi
Comp 2 Cut in 80psi / Out 130psi
Reg set at 90psi
Now with the valve on the discharge Nozzle set a half open and a little less it works fine with a third turn of abrasive valve being turned.
All i get though is about 6 sq inch done before Comp 1 kicks in, then a minute after Comp 2.
Then they both need to run constant to keep the pressure up, it does not drop or get higher.
When i stop blasting Tank one cuts out then a minute or so after Comp 2 cuts outs.
The lines are white 3m 8mm bore to a Y piece with filter then reg, and then yellow 10m 10mm bore to the blast tam filter.
You think it is upto the job. dont want to burn anything out. Ihave been usingn 30m extension lead fully unwound and the cable get warm. Will use two separate leads next time i think.
The set up is
Reg set at 90psi
