gday I'd like to introduce my self I'm paul, long time reader first time poster and I had an idea I wanted to throw out there to see what others thought.
am having water issues like many others have and have found some information on here valuable and some that doesn't work in the hot humid climate we have here in sunny austrailia for e.g. enclousers are a no no as I built one from a hoop frame that hangs of the wall over the compressor and I sew'd a sound curtin to go around it leaving it 2 inches of the floor and wall for air movment as well as manifolding all 3 intakes together to a pipe that goes out side the enclouser with a silencer filter on it.
well good in concept but it actually made the enclouser to hot and started to produce high amounts of water but had that under control with a water trap I made( I got the idea of here) out of 2 meters of inch pipe with outlet of top for regulator and inlet 300mm of bottom and a 1/4 ball valve on bottom to release the water. this worked great but not with the enclouser as I learnt some more and found out you cant drop moisture from hot air. and when I sand blast or use air tools with heavy demand needs I am getting moisture out the exhaust and it blocks the tip on my deadman when blasting. the heat also made the motor cut out on thermal over load one time so it was off with the sound curtin but found out manifolding the inlet and a quality silencer filter actually did more for the sound then the curtin did.
but I was still getting water in lines and learning some more I found that to much negative preasure on the inlet can also make the compressor work to hard adding heat and compounding the moisture isuue so now have 3 smaller individual silencer filters installed and have made the compressor even quieter woo hoo( just using a db app on my smart phone)
now to my idea I wanted to sugest I have scene that in a lot of ideas for moisture removal it involves adding meters of larger diameter pipe into the system to allow the air to have time to cool and slowing the flow rate down to let the moisture drop out of suspension.
my idea is to add an air conditioning condesor I would modify from a car to use as a radiator to cool the air mounting it infront of the cooling wheel(big pully) on the cage. this would split the flow into the fins to let it cool of with more surface area to contact the air that pipe alone provides. and also the added benefits of cooling fins.
now I am wondering would I be beter of cooling the air from the pump to the tank to cool general temps in the tank or from the tank to the regulator to let the incomeing air to blend down with cool air in the tank and then to water trap regulator.
befor people start saying "you cant do that" I am a very competent home enginer enthusiast with a work shop that isn't missing much to do your average home jobs like rebuilding cars from the ground up or building ramjet engines from old truck turbos, what else is a bogan ment to do on a sunday afternoon I ask you. also I work in water treatment and some reverse osmosis machines create 1200 psi operating preassure so material selection and jointing methods is all under control. even if there is a point of failure there is no explosion that a lot of people sugest happens like when homer pours the milk into cearal on an episode of the simpsons once. it will just rupture and realese preassure, also car ac systems work in the 400psi range and my compressor shuts of at 8 bar so there is a safety factor of 4 and braizing copper pipe is proven to 25 bar. with out being rude can post be kept to the concept of the idea and not the execution.
cheers for reading and am looking forward to your feed back on the idea as there are some smart people on this forum because I have found the ozzie forums contain more talk about beer drinking and eating prawns, not theres anything wrong with that.
