This is the type of genie, the unloading valve on mine. http://www.tool-net.co.uk/p-349065/clarke-1-2-bsp-pressure-unloader-genie.html
there £1.50 cheaper at machine mart thats the one i mentioned in earlier post/ re amend that price the robbers are charging £71,98mind u toolnets £6.95 deliverythink I might go for a 4" pulley then , that gives me 1200 rpm at the pump with engine at 3600rpm ,
also will get one of them genie's from your link
cheers
Those pumps suffer the head gaskets going between the inlet to pressure side the bridge piece pops out then then take for ever building up pressure then either seize a piston or burn motor out. Just might be worth checking I have made gaskets out of copper but leave the bridge piece wider into the inlet side to keep it cooler and stronger.
