Spark plug
- Durham, England
Your a bad influence you lot, got me spending money again
do it for 45 years and you rarely buy stuff unless its at give away prices even then do you realy need itYour a bad influence you lot, got me spending money again
. I call that a set of burrs....not a tool. Lol . I was hoping it was one like Double Boost uses.
good man...we all go to the gallows together. funny in my house earlier, "Christine whats your card details as i NEED some drill bits"Drill bits, open ended spanner set, scriber and a deburring tool ordered
https://www.cromwell.co.uk/shop/cut...ce-select-a-drill-set-1-10-00mm/p/ITD0254320WAlmost fell for the drill bits till i found them £5 cheaper at Zoro... https://www.zoro.co.uk/shop/cutting...et-1-0-13-0mm-x-0-5mm-metal-case/p/ZT1132698X those before and afters do look tempting!
Yeah I really should know better.....Almost fell for the drill bits till i found them £5 cheaper at Zoro... https://www.zoro.co.uk/shop/cutting...et-1-0-13-0mm-x-0-5mm-metal-case/p/ZT1132698X those before and afters do look tempting!
If your ordering £40 or more of stuff it might be worth splitting your order into two £20 orders. I received a 20% off voucher to use against my next order which I could have used straight away
Happens all the time here.
Spending money in Scotland John ?, Must be a foreigner, you will be extradited
Bob
A mute point @8ob
He never said it was "His" money.
me too SlimI've had an email confirming my order has been despatched.
