premmington
- Norfolk
For the liquid to turn to gas, it is actually boiling, the boiling point is very low, much lower than the boiling point of water, so forget the 100 degree thing. As it is boiling, or evaporating, if you like, the temperature of the liquid drops, and the lower temperature prevents the transition in gas.
The more you turn the regulator up to counteract the pressure drop, the more the liquid chills. During the summer on hot days, this would not be so much of a problem, but once the weather gets cooler it becomes worse, as the ambient temperature is not warming the cylinder.
Insulating the cylinder will not help at all, only make it worse. The only way to overcome this, is to warm the cylinder, which is impractical, or reduce the burner nozzle size, which again is impractical for the job, or couple two or more cylinders together to reduce the rate of takeoff from each cylinder.
There are no other cures.
We get the same problem discharging from refrigerent bottles - but we use a heated belt - trace heating thing.
Manifolding the bottles does help - reduces the discahrge rate.
