fault on my cut 40 is explained on earlier post,but no replies as yet, thanks for advice.Only place I know of is in Blackburn, as they sell them and may sell boards.
But let the group know what has gone wrong and someone may be able to help with a diagnosis?
I thought mine failed yesterday, would not start the arc, then found that the nozzle was partially blocked, replaced and all OK again, I guess not enough air flow through the unit so a vavle/switch cut in.
Adrian
I would check what the pressure meter is reading sounds like it is just an air problem.
Also and I hope I am not being insulting here, but have you assembled it correctly as in
and not this way
Also note the electrodes are different lengths for different length nozzles.
Adrian
and not this way
Adrian
reset the spark gap on the lower PCB, the contacts are towards the front in the middle. Sounds like the HF isn't up to scratch.
ok i will try different gaps but at the moment there,s no spark when i press the trigger on the gun,so you might be right.ah, that's something I don't know Mine has weak HF and is set at about 1.5mm which might be too much?
i have tried different gaps still no spark from gaps and no arc when operating the gun, took out the swirl ring and the gun arcs but still no spark at the gaps,Want me to put the feelers on mine Gary?
