ajlelectronics
- Gloucester, England
At the moment, I've just added 3 mm all round. That was based on a crude rule measurement from the outside of the torch tip to the outside of the hole in the torch tip.
I wasn't too worried about precision at this point, just repeatability. If I can consistently cut holes with a given template, I can measure the resulting holes and work out what the offset should be and then make a new template to suit.
I'm really, really pleased that the 3D-printed templates are surviving. I expected them to end up a molten mess stuck to the steel. Being able to 3D-print the templates will make it very easy to tweak dimensions and also to lay out holes relative to each other.
Put some making tape on and cut. It will astonish you how much of that survives too!
