Maybe, the grit seems to clog and spurt.Maybe your air supply & nlasting media are already dry to begin with?
CJ
its probably getting 2 much media through and blocking the jet is it a suction gun or a blast pot if suction the pickup needs more air introduced . if blast pot only let a small amount through in to the blast pipeMaybe, the grit seems to clog and spurt.
Is a pressure pot and had the bottom valve fully open. I'm very new to all this.If I close the valve down some, so less grit comes through, will it still come through at the pressure I set on the regulator?its probably getting 2 much media through and blocking the jet is it a suction gun or a blast pot if suction the pickup needs more air introduced . if blast pot only let a small amount through in to the blast pipe
Black SC 120 mesh oriface size I'll check lateralso what size jet and what media is being used
Um I think I'm getting the picture, so any clogging is not, because the grit is getting blocked at the valve and grit exit at bottom of pot? Is too much for the nozzle. So if I have a play with the valve on the bottom of the pot, trying it at various openings through a bit of trial and error I should be able to get a satisfactory resultIf you are running the media valve full open a 3mm nozzle will certainly block.
Too much media is less effective than too little.
The idea is to introduce the right amount of media into the air stream. Too much media and the air isn't able to accelerate the particles up to a speed so they can do their work, even if it could get through the nozzle.
Thanks I looked into this a while back, as only etching glass that has a vinyl mask on it, no bits of this resist come off, so seems no contaminants getting into the grit.I always use a sieve before I fill my pot. Takes out bigger bits.
Ah OK, thanks for the tip I'll get on it.I wasn't thinking of contaminated grit. Even new grit can have the odd bigger clumps in it which will clog the nozzle. I sieve NEW grit!
worth doing because if it has a ball valve for regulation its critical to have uniform media .the Clemco ones with flat regulator are more forgiving that's what I copied mine off I have tried a ball valve one on a pot I made and it was useless always blocking and needed re settingI wasn't thinking of contaminated grit. Even new grit can have the odd bigger clumps in it which will clog the nozzle. I sieve NEW grit!
Not saying I'll get one, "The later issue can be greatly improved by installing a proper media valve " Which would be? I have a 20 gallon pot in which I've put 25Kg of 120 grit SC. I have another 25Kg bag. Have I put the correct quantity in?I wouldn't get too hung up on the different readings you are getting.
Cheap pressure gauges are always a bit approximate but more likely the readings are a function of the flow rates and pressure drops at different points in the system.
If the regulators and pipework can't supply enough air you will probably have a lower reading at the outlet end compared to the gauge just downstream of the compressor.
If you get settings that work for you, the relative readings on the gauges shouldn't matter.
A bigger issue might be the settings changing as the air pressure in the compressor drops (assuming it's not able to keep up with the blast pot) and as the grit level in the blast pot lowers. The later issue can be greatly improved by installing a proper media valve. The former by taking breaks from blasting or getting another and / or a bigger compressor.
Dcal said, " "The later issue can be greatly improved by installing a proper media valve " Is this Clemco the one Dcal refers to or would I have a choice of makes, Clemco sounds expensive? The pot I have is an 20 gallon one from Ebay for 80 quid, with a ball valve. Will upload photo of base ball valve with connected pinch valve assembly on Tuesday.if its a 3mm jet
