Don't forget the 130 volt power supply. It all sounds easy enough.Its a PWN source, ususally a micro contriller like an arduino. there are also H-Bridge contriller chips available. then some high power mosfets and some other bits and bats.
It's definitely 130v.
There is a problem with the control board, possibly the speed sensor, otherwise I would do what you suggest. The speed adjustment is push button, but I guess it could be converted to a remote rotary control.
My original intention was to do just what you suggested, but the board won't work.
Any thoughts on the angled brushes?
The treadmill is (was) a Tunturi J660.
The current lathe motor is an AC job, so no controller - just an Fwd - Off - Reverse switch
Weird,you have to have a controller for varying speeds in metal turning.
Once their 120 VAC is rectified and smoothed with a capacitor it'll be about 165 - 170 VDC. We'll get about 320 VDC from our mains. I don't know what an efficient way of dropping this down to 130 volts (or 180 volts) would be. An H bridge and the PWM circuit sounds easy enough but the power supply to start with has got me stumped.You'll probably find thata its eay for the 'muricuns to use their 120 line voltage rectified easily enough.
I don't know if this is the controller in the above link? but it worth enquiring.
Unusual site that not giving the specs on what it can do.
http://www.plccenter.co.uk/en-GB/Buy/KB ELECTRONICS/KBMM225D9451
Speeds are changed by belts and pulleys.
I reckon that 1.5hp is over-powering that machine so I would say that a 130v controller would be just fine. You'll lose some top-end speed and a bit of torque but you can adjust by belt and still have way more power than the lathe can cope with.
Otherwise you can make a very basic variable DC controller using a phase-angle device and a bridge rectifier.
I doubt whether the motor is 1.5Hp,more like just under 1Hp.
It will rotate off a 9 volt battery, albeit slowly. I hooked mine up to 28 volts (biggest power supply I have), it drew 0.3 amps and turned at 600 RPM.It's a 130v controller that I can't find Pete! Do you think a 90v controller would be ok on the 130v motor?
You'll be at 2/3 power but in all honesty you won't suffer for it, especially if it's a high-rpm motor and you have to gear it down heavily.
That's one of the sites that I've been looking at and getting all my info and ideas from'
All this is above my head to be honest - I need to do some more homework!
The KBMD-240D
115/230 VAC, THRU 0.75/1.5 HP, 1.0/2.0 HP W/HS, 90/180 VDC ARM
is....
115/240v AC switchable
THRU range of motor from 3/4Hp 2Hp
90/180v DC variable. ARM being short for armature
Got the nice facia panel incorporated as well
