Wallace
- Staines, Middlesex, England.
It's a 3hp 2.2kw motor
Sorry my fault, meant to ask zzr1200.
its not one of these new soft start jobbies has to have a 30amp supply, even then the lights dim a bit....
Would a direct on line starter not make life a bit easier?
DOL is effectively the same as a switch, there is nothing to smooth out the starting. Star/Delta is the usual contactor arrangement for a smoother start.Would a direct on line starter not make life a bit easier?
Depends on what if anything you need to comply with, legally, morally, or insurance wise?So is a DOL starter really necessary then for a 3hp motor if it's not left unattended? I'm building another compressor and it would be handy if I didn't really need a DOL starter as they are about £50
So it will work without one, but it's not recommended then. £50 is a small price to pay for safety I guess..
How is that going to give you NVR unless you use an active RCD?Put it on a dedicated spur with the correctly rated RCD in the consumer unit...and use the on/off switch on the pressure switch unit...
Yes, you are right but DOL is not really used as a term for 240v motors either. Single phase usually have a capacitor to smooth out the startingNot on 240 single phase as far as I know, simply on or off...
Totally agree.
My old style 3hp motor has 1 capacitor, I believe you can now get soft start 3hp motors that will run off a 13 amp plug, how many capacitors do they have and how are they wired/switched???
As it reduces the start up current and increases the start up torque compared to a split phase type (for example), I'd say yes it does smooth out the starting, though you are of course correct in the way that it does it.Not correct, the capacitor on a single phase motor is not to smooth, out the starting, it is there to generate a second "supply" out of phase to generate the rotating field to make the motor turn, if it is a start cap.
Totally agree.
