daleyd
- Wrexham, North Wales
Asking for the collective wisdom of the forum, as per title...
Ive got a couple of air die grinders, I tried one today to do a bit of cleaning up and noticed when using it the speed is initially good but drops after a few seconds of use.
Ive got a 20m air line (extension reel type) that I’m using it with, I reckon this is almost certainly the cause of the speed (can’t flow enough air so pressure drop through the hose). I’m going to drain comp down tomorrow and have a check to make sure the there’s nothing amiss with the fittings(blocked with ptfe or something). When you release the trigger you can hear a hiss for a few secs after as if it’s filling the hose again - I’ve used the compressor loads for dusting, plasma cutter, inflating etc and it does this whatever you are doing but using the die grinders is the first time I’ve noticed the pressure drop.
So, is it worth getting a short line for use in the garage (5m would see me reach everywhere in the garage.)? If so any recommendations for a decent, but reasonable priced one? A google search seems to bring up loads of reel type ones.
