Thanks I don't have a dc amp meter but wouldn't be against buying one to check if necessary as I do all my own work to the carsYou can check the resistance of a glow plug without removing them if they are wired individually or you can check the current draw if you have a dc clamp meter. My VW ones usually have a resistance of approx one ohm, not sure on more modern vehicles but you should be able to compare the readings from different glow plugs.
Thanks it could be more than a monthIf it's been more than a month since you last fuelled it or your garage doesn't move much diesel try warming the fuel filter, it could be waxing.
Great thanks allThere is also another method I've used - use a lead connected to the battery + and tap the wire onto the terminal of each glow plug. If there is a little spark, they are drawing current and therefore not open circuit.
Works - however have to be careful with the much newer cars as IIRC they can have 5v glow plugs something like that so could damage them. A common cheapie test lamp could even be used to test the plugs but that's fancy compared to the wire tap method
Interesting.If it's been more than a month since you last fuelled it or your garage doesn't move much diesel try warming the fuel filter, it could be waxing.
Yep, they do.Interesting.
UK diesel fuel does not come with winter additive (anti waxing) ?
My local distributors add it when delivering in the winter as a normal thing.
Read my first question haha I bought some but haven't used any yet as I was questioning the instructions lolI see no ones mentioned that dreadfull stuff easy start,DONT,maybe if your really deep in the poo poo,but to much use and the damn thing will never start without at any time,ask me how i know
Interesting.
the best is take the air filter off get an oily rag light it and stick it over the intake and crank the engine black smoke goes in with a bit of flame and off it goes used to start my twin lister with it in winterInteresting idea will definitely bear that in mind for future non starts
Haha erm not sure I'd have the nerve for that one lol!the best is take the air filter off get an oily rag light it and stick it over the intake and crank the engine black smoke goes in with a bit of flame and off it goes used to start my twin lister with it in winter
Thanks yeh potentially someone also mentioned a hot air gun in air intake which might be an ideaMy dad would tell me tales of doing that to start lorries in the 40's, he would use a blowlamp to warm up the intake manifold on his Landy in the 70's.
OP could try warming the manifold with a modern gas torch?
Inlet manifold is likely plastic .........My dad would tell me tales of doing that to start lorries in the 40's, he would use a blowlamp to warm up the intake manifold on his Landy in the 70's.
Thanks yeh that's right intake is a plastic manifoldInlet manifold is likely plastic .........
With ANY diesel, its always best to fit the biggest and highest capacity possible. OP said battery is quite old, and car gets infrequent use, so IMO this will be the problem.
If you do resort to using easy start, Spray into the intake for a second, then try to start ASAP. If it catches, it will make an awful clacking noise for a few seconds. If it stops, repeat.
Whatever you do, DO NOT stand there constantly spraying while someone cranks the engine. If it does start, this is highly likely to cause damage.
If you do try to remove the glowplugs, be aware they are quite fragile, and sometimes seize in the cylinder head and snap off if you apply too much force.
My statement wasn't directed at you/your first questionRead my first question haha I bought some but haven't used any yet as I was questioning the instructions lol
Test them first and if they are ok leave them well alone unless you want to fit a new head gasket as well...glow plugs I'd like to change them
