Do you have the electrical supply to run that?
I bought a big leccy screw compressor a few years ago without first reading the power requirements, it needed 63 amps of my 100 amp supply to run so it went in the scrap.
Bob
whys. that depending on what your other requirements are power wise and how often the comp is going to be used the supply will take it no botherI bought a big leccy screw compressor a few years ago without first reading the power requirements, it needed 63 amps of my 100 amp supply to run so it went in the scrap.
Bob
as above it would only be just over 20 amp each phase
a 130 comp will run bigger than a 6.0mm jet my 90cfm runs a 6.0mm no bother or an 8.0mm nozzle @ 90psi with a 125cfm compI am looking at a 130cfm 22kw Hydrovane to run a blast pot for my blasting room. I am unsure what would workout cheaper.
To buy a road compressor or run such a big motor from the hydrovane.
Whats your thoughts, was hoping to run a 6mm nozzle for prepping wheels.
