Raining on you`r parade again but you need a 1/2" port reg, and bigger bore airline.
I think eil could be right here, you'll get quite a pressure drop over 50m, especially running a mask and gun from the same line, but then if it works, no prob!!!
deffo need 1/2inch pipe there best use eurofittings as well there a larger bore
It was in the vizi instructions which I cant get me hands on now it asked for a minimum 10mm or 3/8" airline but that was for both gun and mask as already said. Ive got my supply to the filters coming in on a 3/4" copper pipe with 1/2" BSP fittings then 10mm bore 10M length airline, had to have the regulator cranked up to near 100psi to keep 30 psi at the gun, but as you said you will be using a separate feed for each, a case of suck it and see let us know how you get along.
